Xiaomi Robot Vacuum S12 - Homey Integration
Hi everyone :waving_hand:
I have a Xiaomi Robot Vacuum S12, and I’d like to know if it’s possible to integrate it with Homey.Are there any workarounds or recommended methods to control it through Homey?
Thanks in advance :folded_hands:
Have you tried this app?
In case that doesn’t work, you can use a workaround. Install the Virtual Devices app on Homey and install the Google Home app on your phone (you don’t need a Google Home device for that). Select the type “Kettle“ for the virtual devices (that’s the only type that works with Google Home). Then, you can go to + button → Add automation, and create an automation like this:
When:
-Virtual device turned on
Then:
-Start robot vacuum
Then, you can create a Flow:
When:
Then:
-Turn off virtual device after 10 seconds
Google Home should now trigger the robot vacuum when the virtual device switches on. It’s still a workaround so not everything is supported, but you should be able to integrate most basic functions.
Thank you…
After several tries and research how to get token i could integrated with this app Xiaomi Mi Home, now its workink with basics command at list…
thanks a lot for helping…
