Write/read NFC contents?
Here’s an example:
Please don’t be confused with “Homie” and Homey.
“Homie” is just a framework for you to get started with MQTT and has nothing to do with Homey.
Homie is not necessary, but might make it easier to set up a system if you’re not familiar with Arduino/programming.
Install Mosquitto broker on Homey. This all might be a lot to get your head around at first, but once you get the hang of MQTT, you’ll see a lot of possibilities for your system.
Tasmota + Wemos D1 Mini or any Sonoff device f.ex.
All models from “Early 2019” and later, that includes the pro version, will not have the NFC antenna or microphones internally.
You can check which model you have in
More… -> Settings -> General
I do have an early 2018 modell :sunglasses::sunglasses:
I Am used to work with nodemcu esp286 modules. But not aware of mqtt
Then you’ll probably like it :slight_smile:
