WOOX R7060 smart garden irrigation control
Is there anyone that has experience with the WOOX R7060 ?
It seems it can be added as a generic zigbee device
Don’t have experience yet, but I’m considering to buy it too. My idea was to buy the Woox-hub (€22,-) and connect it via a detour to Homey. For example with the Alexa - Homey app (trigger a routine).
Nevertheless, your idea is better since it will save a hub and some money :slight_smile:. Hope someone else already has experience with this device!
is there an advantage in using this hub ?
I’ve read on github this might be a tuya zigbee device @johan_bendz .
Might buy this item soon
Yes, most probably. You can use the Woox app via the hub and it should also be possible to connect it to Homey via the way I described above.
But, when it can be connected to Homey as a Generic Device or via Tuya it will even be better, right? I just bought it, when I tried it I’ll share my experience here
From what I can see here: Woox R7060 Smart Garden Irrigation Control · Issue #4325 · dresden-elektronik/deconz-rest-plugin · GitHub
The only advantage would be battery status.
If you can query it maybe @johan_bendz can add it to his app?
@Wolter let me know how it works for you
SKU: WOO_R7060 (RobbShop)
Talks with homey if you include it as a generic zigbee device
I received the WOOX R7060 today and did a small test. It can be connected to Homey as Generic Zigbee Device. It works very well! Now I can use it in a flow to control my (to be realized) irrigation system.
Mine came in also today. Added him as generic device. All you can do is just on/off.
Would be nice to have battery status tough.
You have to do a query in the developer site of your homey and share this with @johan_bendz , he can add it to his app. As it is tuya
http://developer.athom.com/tools/zigbee
That is the “interview” button ( for query)
@Rens_Hoekema Where do we contact him? Here? Just by tagging him?
Already got a query ready in a notepad.
in this topic: https://community.homey.app/t/app-tuya-zigbee-app/26439/1114
Ik heb de Woox zonder hub werken. De woox app werkt nog niet , maar met Homey kan ik de watertoevoer bedienen.
Ik heb dat ook zo gedaan. Maar zou je dit ook zo kunnen instellen met een flow dat er rekening word gehouden met het weer? Bv, droog en warm dan een extra sproeibeurt?
If you could please keep the conversation in English as much as possible, then more people will be able to participate and help you. If you would rather not or can’t communicate in English then please check out Non-English boards/catregories:
https://community.homey.app/c/non-english
Or here:
Nederlands (Dutch),
Dansk (Danish),
Deutsch (German),
Svenska (Swedish) ,
Français (French),
Polskie (Polish),
Fiński (Finnish)
You could use the KNMI app in combination with the buienradar or Buienalarm app
I made a flow for this based on a timer. If it stops raining (BuienAlarm app), then start timer for 36 hours. If it starts raining or is going to rain within the next 24 hours: reset timer.
Homey will check the following every day at 20:00:
Has the timer ended and was the temperature that day higher than 15 degrees? If yes, then start sprinkler and stop it after 90 minutes. If not, check again next day 20:00.
Hello Wolter, Thanks for your answer.
Do you have an example of what your flow looks like?
And want to share it with me?
I am still a beginner with creating flows.
Thanks
