Hello, I’m struggling to come up with a function/flow…
I’m planning to have an HP23 to control some garage doors at work. There are 8+ people working there, and we will mainly only operate the gates during working hours and when we are present (in close proximity of the garage door).
Sometimes we need to be able to open and close them outside of working hours, and when we are not present. In those cases I would like to use a “confirm question”- flow card to make it a little safer.
The problem is that I would like to get this confirmation from the person that pressed the button/tile in the app, and not a fixed person every time.
If: “C” pressed “Open garage no.3”
And: “C” must confirm: “Do you want to open garage no. 3”- “Yes/No”
Then: “Garage no. 3” opens or not!
If :“A” pressed “Open garage no.5”
And: “A” must confirm: “Do you want to open garage no. 5”- “Yes/No”
Then: “Garage no. 5” opens or not!
Another possibility would be to use a PIN-code to be able to control the garage doors when not present?!
If: “B” pressed “Open garage no.2” outside working hours/ not present-
And: “B” confirms with PIN-code
Then: “Garage no. 2” opens or not!
Hopefully this makes sense ![]()
Does anyone know how to get this function? Like a virtual button of some sort that is accesable in the app?
Thanx ![]()
Chris
