Which humidifier is fully integrated in Homey?
Hi there!
I’m considering to buy 2 humidifiers for my house but I would like to have a 100% integration with Homey. Water tank level reading (or at least “empty tank” notification) would be a plus. Appreciated also the function “hot” or “cold” steam Price range indicatively 80-120€ each.
I have an Inventor dehumidifier (Midea brand) but unfortunately at today it’s not supported by Homey; for this reason I’m asking your suggestions to buy a suitable humidifier.
Thanks in advance, ciao! :wave:t2:
I build in a aqara watersensor to measure waterlevel. Works great.
For humidifiers: also take a look at “air washers”.
  • Their capacity is less (but more then enough for creating normal humidity)
  • but they last longer since they are not sensitive to calcify.
    Ultrasonic and steam humidifier will soon calcify and stop working
  • and no risk on adding too much moisture
I’m not sure what size you are looking for but the SwitchBot Humidifier is compatible with Homey.
Thanks FKey,
I didn’t know this type of device. They seem to be much more expensive than a “traditional” humidifier. I have some air purifiers (Xiaomi and built-in in Daikin aircon splits).
Anyway I keep it in consideration, thank you!
Thanks Adrian,
I have 2 floors about 80-90 sqm each, but it would be sufficient to reestablish a correct humidity in the base floor (at least living room) and in the bedroom.
Thank you for your advice, I will consider the suggested device.
That is correct, but it really pays off
I owned a ultrasonic and a steam humidifier. Both died because of calcifying just after guarantee.
My current washer has been running for over 13 years now without any issues.
And the washer has more advantages:
  1. it washes the air.
    Particles in the air are captured and washed into the basin.
    It cleans the air.
    You can see it when you clean the basin once in a while
  2. Its silent: the ultrasonic has a low buzz and the steamer you can hear blowing
  3. The steam version is risky for children (hot)
Tip: make sure your water reservoir is large enough!
When your heated rooms is ventilated well you will need to add a lot of water to keep it at 50% (>3 liters per day)
You can calculate how much water you need:
1 decide how much air is refreshed with outside air / hour (you can find standards on the internet about healthy ventilation vs #persons (40m3/hr/person)
2 determine the desired inside temp and humidity
3 determine the outside temp and humidity on a freezy day
Use a humidity calculator (internet) to convert the m3/hr fresh air of outside temp and humidity to desired inside temp and humidity.
4 be shocked finding that you need 0.3l water/hr to keep the desired humidity
I am searching for a (larger) humidifier that integrate in Homey as well. Preferably 45-60 m2.
Anyone added humidifiers via the Tuya app?
I found this one, which I like and which connection is based on Tuya:
And what about the Xiaomi ones?
As a workaround (not preferred):
I could use a “dumb” humidifier as long as they switch one when power is supplied (by a smart socket). I already have several humidity sensors in the room. As long as the device is suitable for around 45-60 m2 and has a large capacity water tank.
Can You give us some manufacturers and models?
Humidifiers compatible with Homey:
Based on your requirements, here are some humidifiers compatible with Homey in the 80-120€ price range:
1. Xiaomi Smart Humidifier 2:
  • Price: €80
  • Homey Integration: Yes
  • Water Tank Level: Yes (both level and empty tank notification)
  • Hot/Cold Steam: Yes
  • Additional features: App control, voice control (Alexa, Google Assistant), adjustable mist levels, automatic shut-off
2. Levoit LV600HH:
  • Price: €100
  • Additional features: App control, voice control (Alexa, Google Assistant), aroma diffuser function, automatic shut-off
3. SwitchBot Wi-Fi Smart Ultrasonic Humidifier:
  • Price: €120
  • Water Tank Level: No (only empty tank notification)
  • Hot/Cold Steam: No (cold mist only)
  • Additional features: App control, voice control (Alexa, Google Assistant), essential oil diffuser function, top-fill design
4. TaoTronics TT-AH-001:
  • Price: €90
5. Honeywell HEV615W:
  • Price: €110
  • Homey Integration: No
Can you please prove the compatibility of the following humidifiers:
  • TaoTronics TT-AH-001
  • Honeywell HEV615W
Which apps are required for these humidifiers?
Honeywell HEV615W
Are you kidding me?
my suggestion: “Midea EU SK105 EU SK103 WiFi Air Modul”
