We created an if function using the AND key for our INNR SP240 power switch. On the Homey edit screen, we no longer see the name “Switch-1”. Do we need to do something to make this name visible?
That would be, because those are the standard logic cards just conveniently available from the device also. Logic cards are not device specific, only the tokens you use with the logic cards are.
Thanks for the information!
In addition to the above: as you can see in your own screenshot, when you hover the mouse over the device’s tag (in this case the Power tag), the flow editor shows the device to which the tag belongs: ‘Switch-1 - Power’.
Also thanks, but viewing to the editor it should more handy to see more info instead moving your mouse!
Yes, that would be a nice feature. For now, this is the work-around.
