Get device Name from the device (Tuya) in an advanced flow
Is it possible to retreive the name of the device in an advanced flow?
It is about a Tuya device and I want to send a message if it is turned off.
I have tried a script (made by ChatGPT), but I cannot get it to work.
In other words: you like a condition which states if that device is on or off?
If so, you can add an ‘And’ logic card [value] is equal to Yes, and add the tag from the Tuya device.
Thank you.
I am looking for the device.Name
If I add a device to Tuya (and give it a name) and then add it to Homey, it gets the given name.
In my flow I want to use that name, but cannot retreive it.
If I can get the device.name, I can use it for more purposes; now I have to do it manually with a extra tag.
I want to get the M-3… name
Hi Gerard,
I clearly don’t get your use case, can you give an example of what you trying to achieve?
Which card or event should provide for the device.name?
Thanks for the reply.
I want to get the name of the device in the advanced flow (and store it as a variable) so I can copy the flow for (a lot) more machines without entering the devicename every time.
But I think it isn’t possible with (unknown) Tuya devices.
Maybe you can use the capability watcher card from the Device Capabilities app.
It returns a number of tags, including the device name. You can use it to watch the on/off state of your switch.
