Hi Homey customers,
I have Warema Awning with Warema WMS radio system, basically a wi-fi remote to control the extension of Warema Awning.
I looked at Community because I wanna integrate it in Homey Pro.
Many of threads are in German and in addition there are no similar use cases (control the awning/sunblind). Anyway, after a while I found how to do it using Homey Pro flow.
Here you are.
First you need a simple “switch” from VirtualDevice (WHEN) to open and close it
As THEN you can use Logic from Homey Pro, more specifically a Make a POST request, as follows:
Make a POST request to
http://IP_LOCAL_ADDRESS_OF_YOUR_WMS_WIFI_DEVICE/commonCommand
with headers
Content-Type: application/json
and body
{“protocolVersion”: “1.0.0”, “command”: “action”, “source”: 2, “responseType”: 0, “actions”: [{“destinationId”: ID_NUMBER_OF_YOUR_SUNBLIND, “actionId”: 0, “parameters”: {“percentage”:100}}]}
Basically when percentage is equal to 100 is open, when equal to 0 is closed and you can even use a parameter to do that.
By the way if you have a light embedded in the sunblind the logic is the same, just you need to change the ID number of the light instead of the sunblind.
Hopefully this helps.
Sunny
