@Abe_Haverkamp I do not know where to address the issue, but is there any problems regarding variables?
I have some flows that has stopped working and everyone is based on variables.
Fredrik
Fredrik
What changed in your setup?
Did you try rebooting your Homey?
Can you show an example (screenshot) of a flow that does not work anymore?
I’ve had some issues since the last firmware update when Flows just randomly refuse to run, and the error reported relates to missing/bad variable/token. And sometimes when I open the web editor for Advanced Flows all the variables in the Flow will be greyed out and missing, until I close and re-open or clear the browser cache and refresh, sometimes requiring more than one refresh, then they all reappear and a manual run of the Flow then works fine.
I have all the usual rebooting Homey Pro, running the USB Tool and reapplying the latest firmware version, restoring Flows from last night’s backup. I haven’t seen any discernible pattern to it either. But I will do more testing if/when it happens again.
Here → Support | Homey
