Flows stop working
A little while ago several of my flows stopped working.
It’s all the flows that have to do with lights and motion.
I my basement the flow simply don’t turn on the ligth. In my kitchen the ligtht turn on and off with seconds between when I walk around.
I have deleted all lights and flows in the kitchen, and created new (simple) flows, but that didn’t help.
The lights and sensors is Philips Hue.
It has all worked perfectly fine, and I haven’t done anything, till a months or so ago.
Any takes on the issue?
Upload a screenshot of one of the failing flows, to make it easier to help you.
Have you tried to trigger them manually?
Are they disabled?
Have you tried to restart your Homey?
Same problem, some lights will not go on or go off after the motion (Hue Motiondetectors). Did you find a solution yet?
