Vallhorn not working in flow
So last week I bought a Dirigera hub, Parasoll sensor and Vallhorn motion sensor. Integrated all the Ikea devices from Tradfri to Dirigera and all lights, screens and buttons are working flawless. The Parasoll sensor also works perfect in Homey flows.
To play around with the new Vallhorn sensor, I created a simple flow; if motion is detected and it is after sun down, then turn on the light. Well, nothing happens.
If I look in the detections on the sensor, it does detect movement. I tried removing the sun down trigger, doesn’t help. The light itself is a Philips Hue light, which works perfect in other flows.
Anyone a suggestion as to where I could look to troubleshoot? (I am using the Ikea rechargeable batteries)
You’re using a condition card (“AND”) instead of a trigger card (“WHEN”).
The card “De bewegingsmelder is aan” should be replaced by the card “De bewegingsmelder gaat aan”.
oh wow. Deeply ashamed now :rofl:
That did the trick! How I mixed those up I don’t know. Thanks for the quick reply!
