Using homey pro to give inputs to google nest mini / hub
Hi there,
i am experimenting with advanced flows and want to do 2 things:
  1. give google assistant inpunts/commands via homey advanced flows.
  2. use a advanced flow to make google nest mini/hub make sound effects (for example to use it as a chime)
is any of this possible? i downloaded the ‘cast a text to google’ app but that only outputs text.
kind regards,
Mees
  1. Howto: https://community.homey.app/t/controlling-devices-at-google-home-from-homey/73201/17
  2. Sounds: install Chromecast app; when you add devices, the nest mini and hub should pop up.
