Using a wired z-wave switch + Hue
I’d like to install a z-wave wall switch (neo coolcam 2CH EU) and use it to switch hue lights. How should i fix the wiring? can I bypass the switch in order to provide Hue-bulb with constant power?
Sorry for the question, why you would to use this Setup? Maybe it is Overkill to have a Z-wave switch and Hue Lights together.
By setting the Hue lights to ‘return to previous state’ (which is semi new) it means that you can continue to use your wall switches as well as use Homey + Flows to control your light.
In addition to that - you can also change the colours/tempreature of the globes.
Well thats what I use it for … Just don’t use them with a zwave dimmer.
