Using a switchbot matter enabled hub mini with homey
i use switchbot with homey app, but its linked via switchbot cloud (as the app is not connected directly to the hub)
is it possible to use homey matter to connect locally to the switchbot hub to control switchbot devices? for example the switchbot curtains are to be connected via bluetooth, from the hub.
there is also bluetooth on the homey, but it has bad coverage.
Works really well! Use it myself to connect the Lock Ultra via Matter, using the Hub Mini
I also use it to connect the Switchbot Lock Pro to my homey pro (early 2016) and it works well.
Is it also possible to use the hub mini for other matter devices?
I know my homey doesn’t support matter but it would be nice to use this hub to connect a sensor I have. When I start the sensor then my phone shows me Google Home but not the Switchbot hub mini.
Anyone hints how to get this working, if possible?
The SwitchBot Hub Mini doesn’t support Matter
There’s now 2 versions apparently
This is the vague statement
I’ve read that statement so I think it should be possible but I can’t get it to work yet. I’ll try some other ways. I’ll let you know what I find out.
