User input in flow
Hi
Is it possible to give user input to a flow like date/time or a numeric value.
I know about the push notification option, but that’s only yes or no from what I can see
Usecase, set the home inn “eco” mode from date to date, or input the number of days away
One option is to use iCalCalendar app.
That way you can trigger flows dependable on the event start / end date & time.
Hi, thanks for the tip, i will take a look at that.
Maybe not completely usable for your use case, but I’m using Tasker on my Android phone with several plugins (Join, Auto Tools, Auto Voice, Auto Notification) as a way to input data to flows in Homey.
The two are connected through webhooks and via this mechanism I send data from my phone to Homey and vice versa.
For instance, I have a flow which let me know when there’s movement upstairs. But when my children are going to bed I want to disable this flow temporarily. On my phone I have a Tasker task with which I can disable this flow with one press of a button. The Tasker task flips a variable in Homey.
Another example: I have several Google Nest speakers placed in my house. I have a Tasker task that, when I activate it, asks me where I want my voice command to be broadcasted. When I choose one, my phone asks me for my voice command and the text from this command will be sent to Homey via webhook, the appropriate flow will pick it up and the text will be broadcasted by the app Google Services on the selected Google Nest speaker.
So, many ways available to give Homey your user input for flows.
ok, nice will take a look at this.
I made a short tutorial about two-way communication between Homey and your Android phone:
in my use case I need to enter a number into a flow card, which is then used in a webhook to adjust the volume of the doorbell.
So my trigger card is now “Start flow the a number tag”, but of course this only works in the desktop test setting.
On top of that, I am a iPhone user… :wink:
Any solutions/suggestions?
Regards
Philip
Regardless of phone OS:
