Use Fibaro UBS inputs
I’ve got a Fibaro Universal Binary Sensor hooked up to a simple magnet switch and a temp sensor. I want to create a virtual device that gets it values from the universal sensor.
As a virtual device I’ve chosen a garagedoor and I can get the temperature value to update according to the Fibaro sensor, I can’t get the state of the input one from Fibaro sensor to carry over to the virtual device. The fault I get can be seen in the screenshot.
As I understand it the virtual device expects a boolean input but the Fibaro sensor is outputting a string value, am I correct? How might I solve it? :slight_smile:
That’s strange, the Flow looks correct. Are you sure that there are no spaces/other characters in the value (other than the tag)?
I just checked and there is no spaces or anything else.
Is there something else I can check or do? How should I interpret the fault?
