Updating devices takes really long for IKEA motion sensor
I have two IKEA motion sensors and the second one is currently updating the firmware through the Homey app. It is currently at 53% and has been running for over 5 hours. Is this normal? Is there any way to speed it up?
Maybe the sensor is going to sleep and you need to wake it periodically via its button?
Yeah, that’s at least why I put it in proximity of Homey and am making sure there is some movement every now and then
To speed it up. Connect it to a ikea dirigera hub and it will update fast
In that case I just need patience as I don’t have an Ikea Dirigera hub
This procedure worked for me… Matter OTA Updates - #27 by Rammstein
Of course i had Myggbett devices…but maybe this helps you when you do the same steps instead of the contact signal you activate the motion sensor till the end.
In the end it did finish
I had a similar issue. What solved it for me was moving the sensor right next to the Homey hub.
I then went into the device’s Maintenance menu and clicked Repair. With the sensor right next to the hub, Homey was able to recognize it immediately.
After that, I started the firmware update, which completed surprisingly quickly — in just about 30–40 minutes.
Finally, I moved the sensor back to its original location and ran the Repair process again.
