Update of SHS on Synology
My SHS shows me a new update at version 12.11.1.
But I can’t update the system this time via the synology container solution.
It always pulls the version 12.11.0 from Athom’s server
Did somebody updated the system successfully?
Simply install Watchtower and it will take care of it.
You can follow this guide on installing it :
Don’t think that solves my current problem.
But for the future it can be helpfull
Hm, I see, officially latest is Homey Self-Hosted Server v12.11.1 , have you tried : docker pull ghcr.io/athombv/homey-shs:12.11.1
OK, got it… 12.11.1 is marked as BETA but it’s not marked as Beta on the changelog. Have you tried enabling Homey Developer Tools Experimental updates ?
obrazek
Actually, seems you have enabled Experimental updates…so when you disable it, no updates will be shown :rofl:
(I know that’s probably not a solution you are looking for, so probably only way is to update it directly using pull with exact tag)
Experimental updates are enabled
SHS seems to be a better BETA Solution. Like everytime when IT Companies starts a new system
Watchtower is a great and reliable app, but when an update has breaking changes, you’ll have a surprise coming.
I’d rather use Dockhand to check for updates (you can have a notification too). That way, I can check upfront what the changes are and manually update.
See:
And here for tips & trick, including a link to the installation guide:
I also only managed to update SHS to v12.11.1 when pointing to the exact version ghcr.io/athombv/homey-shs:12.11.1
Thanks @Sharkys!
