Unable to add most new zigbee devices - they add then leave the network
Unbelievably frustrating. This is a Homey Pro 2026, with zigbee on channel 25. Local network is Unifi, with 2.4GHz channel 11 disabled, so no overlap with zigbee channel 25.
For whatever reason I can’t seem to add any new zigbee smart plugs (or some other zigbee devices). I’ve had 4x ThirdReality ones for almost a year, and they’ve been perfect. I got another 4-pack of the gen3 ones, and nothing but issues.
  • Device adds fine, am able to turn plug on/off, see energy etc.
  • 10 seconds later it drops from the network - Homey app shows the blue “Try to repair”.
  • Repair works fine, and it’s back for another 5-10 seconds, then drops again.
After multiple tries ONE plug added long enough to allow the firmware update to work. Went from 046 to 056, and it’s been stable since. The other 3 - nope. Tried another 4-pack. NONE of them would join for more than a few seconds.
Tried a Sonoff iPlug gen2 (S61SZBTBP) - same damn thing. Adds as a generic zigbee device, works perfectly (even though Sonoff app doesn’t know about it yet) then drops off.
Yet a Sonoff SNZB-01P zigbee wireless switch added and worked fine, and has been working fine. A Besiglas ZB-BT01 zigbee wireless switch ( Amazon.com ) fails with the same join/work/drop cycle.
I originally thought it was a problem with ThirdReality when that set of 4 wouldn’t add. About 6 months I got some of their soil moisture sensors and they do the same join/work/drop crap. So I tried the Sonoff iPlug Gen2 (to no avail).
BUT - those soil sensors joined a Home Assistant setup (at a friend’s house) perfectly fine. And I’ll bet a lot that the ThirdReality Smart Plug Gen3 and the Sonoff iPlug would all join there too …
I noticed this thread Fix: Zigbee device joins but Homey says “unable to connect” (delete stale bindings) and tried that. Repaired the Sonoff iPlug, refreshed the bindings popup, deleted the 3 bindings listed (On/Off, Metering, Electrical Measurement) even though the target was my Homey Pro.
The iPlug dropped as expected, I repaired again … and no difference :frowning: 5-10 seconds working perfectly, then bye-bye GONE.
Any ideas ?
Do you have a Hue bridge as well? Those often use channel 20 or 25 and may cause interference. You can change Homey’s Zigbee channel in the developer tools:
I also have a similar issue with Sonoff motion sensors where they stop responding after a few days and only a reset can fix it. On the eWeLink bridge (ZBBridge-P), there is also this issue, but on the ZBBridge, the devices even disappear from the eWeLink app entirely. Since the same issue occurs on the official Sonoff bridge as well, I think it might be an issue with Sonoff devices or maybe they’re more sensitive to interference
For my ThirdReality devices I use the Smart Hub Gen2+ with the ThirdReality Hub homey app, so I don’t have any experience with those using Homey’s Zigbee.
No Hue here at all. The most 2.4GHz interference is from a couple of neighbors with 40MHz on channel for their wifi. No real impact on the 2.4GHz here.
The fact that several different devices exhibit the SAME damn problem - join, work for 5-10 seconds, the fall off the network - leads me to suspect Homey. PLUS, devices that fail to work with Homey work perfectly fine with HA. And this is with the devices literally 1m from Homey during the Add or repair process.
You can find similar topics with similar zigbee issues. Own a Pro 2026 after several years running Aqara devices seamlessly on a Pro 2019.
Pro2026 has Zigbee issues and i was so tired of it. Purchased a separate Zigbee antenna and setup Zigbee with Zigbee2MQTT. Everything works fine again
Setup on a different device, or on Homey 2026 ? I think one of those PoE zigbee antennae would be cool.
But it really, REALLY gripes me that something like that would be necessary. Hrm, if I get one of those I can try HA here on a spare machine. If those devices join cleanly like at the friend’s house, then it’s definitely a Homey problem.
Honestly, I’d jump ship now, but I have a metric sh1t-ton of flows etc. that would all need to be rebuilt. Hrm, I do have opencode talking to Homey, and my backup system GitHub - Halfwalker/Homey-Backups: # Homey Backup & Restore Tools A set of Python scripts to **back up**, **restore**, and **visualise** devices, flows, zones, and variables from a Homey Pro instance via its local REST API. No cloud, no MCP, no add-ons required. · GitHub I’ll bet I could point opencode at Homey, the backups and an HA instance and say “Duplicate this on HA” …
Do all of your Zigbee devices have issues? You can also perform a Zigbee reset from the developer tools page. Note that all of your Zigbee devices will be unpaired when you do this, so you would need to pair them again.
For ThirdReality I can recommend the Smart Hub Gen2+, it works very reliable. The hub can connect to Homey with the ThirdReality Hub Homey app.
Zigbee2Mqtt and Mosquito are running with Docker on my Synology NAS. With the Zigbee2Mqtt app on Homey i have added all my devices.
I can recommend to let go and stop trying to understand why :face_with_open_eyes_and_hand_over_mouth::smiling_face_with_tear:
A join, work 5-10 seconds, drop pattern on several different mains-powered devices usually points to a routing or parent-selection problem rather than to the devices themselves, so I would test it like this:
  1. Isolate the mesh. Temporarily unplug your existing routers (the four older ThirdReality plugs and any other mains-powered Zigbee devices), then pair one new plug right next to Homey. With no other router in range, the plug can only join directly. If it stays online, plug the old routers back in one at a time and watch which one makes it drop.
  2. Pair each new device one by one, wait a couple of minutes after the join finishes (the interview and binding phase), and only then move it to its final spot. Do not pair several devices at once.
  3. Check the channel. Zigbee 25 sits at about 2475 MHz, which is above Wi-Fi channel 11 but can still be hit by neighbours’ 40 MHz channels in the upper band, and some devices handle the top channels worse. If your Homey firmware allows it, try Zigbee channel 15, 20 or 11 and check that your Wi-Fi is not on 1/6/11 close to the new channel.
  4. Keep Homey away from USB 3.0 drives, NAS units and metal enclosures, which raise the 2.4 GHz noise floor.
  5. If a device keeps dropping, factory-reset it properly (hold the button until the LED pattern changes) before each new pairing attempt, so no stale network key remains.
Which Homey firmware version are you on, and can you post the Zigbee mesh view (parent device and link quality) for the plug that drops?
One more thing worth trying is pairing the new device right next to Homey, within a metre or so, with the older router plugs still switched off. If it stays joined there, the problem is more likely the mesh route than the device itself, and you can then switch the routers back on one at a time. It is a slow way to test, but it helped me narrow down a similar dropping problem.
