[TUTORIAL] Homey SHS on Proxmox Interactive installer
After a question about how to migrate to a Proxmox Homey SHS environment, I have created an interactive installer. With this installer you are able to install Homey SHS on Proxmox with some more flexibility:
  • You can choose your storage (current Athom installer might refer to storage that doesn’t exist)
  • Select a VLAN (if bridge is VLAN aware)
  • Disable auto start of Homey SHS (to migrate data)
  • Disable auto update (for those who like to be in control of when an update starts)
You can view the script before you use it over here.
Homey Self-Hosted Server - Proxmox Interactive Installer
An interactive version of the Homey SHS installer for Proxmox VE, featuring a user-friendly wizard interface and additional configuration options.
Why use the Interactive Installer?
The standard Homey SHS installer uses fixed defaults (local, local-lvm, vmbr0). This interactive version offers:
  • Storage selection - Automatically detects available storages instead of assuming local and local-lvm
  • Network bridge selection - Detects all available bridges instead of assuming vmbr0
  • VLAN support - Configure VLAN tags on VLAN-aware bridges
  • Auto-update control - Choose whether to automatically pull the latest Docker image on restart
  • Migration support - Option to skip starting Homey SHS, allowing you to restore userdata first
Requirements
  • Proxmox VE 9.x (uses Debian 13 template, same as official Homey installer)
  • Root access to the Proxmox host
  • Internet connection
The following tools are required (included by default on Proxmox):
  • whiptail - For interactive dialogs
  • jq - For JSON parsing
If not present:
apt update && apt install -y whiptail jq
Installation
Direct execution (recommended)
bash -c "$(curl -fsSL https://raw.githubusercontent.com/anoniemnd/homey-shs-toolkit/refs/heads/main/Proxmox_Interactive_Installer/homey-shs-proxmox-interactive.sh)"
Manual download
curl -O https://raw.githubusercontent.com/anoniemnd/homey-shs-toolkit/refs/heads/main/Proxmox_Interactive_Installer/homey-shs-proxmox-interactive.sh
chmod +x homey-shs-proxmox-interactive.sh
./homey-shs-proxmox-interactive.sh
Installation Steps
The wizard guides you through each configuration option:
Step 1: Container ID
Enter the container ID, default the first available ID.
Step 2: Hostname
Enter the hostname, default homey-shs.
Step 3: Template Storage
Select the storage for the container template
Note: This dialog only appears if multiple template storages are configured. Otherwise, the only available storage is selected automatically. (screenshot for reference)
Step 4: Root Filesystem Storage
Select the storage for the container root filesystems.
Note: This dialog only appears if multiple root filesystem storages are configured. Otherwise, the only available storage is selected automatically.
Step 5: Network Bridge
Select the network bridge.
Note: This dialog only appears if multiple network bridges are configured. Otherwise, the only available storage is selected automatically. (screenshot for reference)
Step 6: VLAN Tag (optional)
Enter a VLAN if required, otherwise leave blank
Note:: Only shown if the selected bridge is VLAN-aware.
Step 7: Resources
Resource Default Minimum recommended
Disk 16 GB 8 GB
CPU 2 cores 1 core
RAM 2048 MB 1024 MB
Swap 512 MB 256 MB
Step 8: Root Password
Enter the root password, default: homey
Step 9: Autostart Homey SHS after installation
Choose whether to start Homey SHS immediately after installation:
  • Yes - Normal installation, starts immediately
  • No - For migrations: restore userdata before first start
Step 10: Auto Update Homey on restart service / LXC
Choose whether to automatically pull the latest Docker image:
  • Yes - Pull latest image on every service restart (Default)
  • No - Only pull if no image exists locally
Step 11: Confirmation
Review all settings before installation begins.
After Installation
Access
Type Address
Web interface http://<IP>:4859
SSH ssh root@<IP>
Important paths
Path Description
/root/.homey-shs/ Homey userdata
/usr/local/bin/homey-shs.sh Deploy script
/tmp/homey-shs-install-<CTID>.log Installation log
Management
# View status
pct exec <CTID> -- systemctl status homey-shs
# Restart
pct exec <CTID> -- systemctl restart homey-shs
# View logs
pct exec <CTID> -- docker logs homey-shs
Manual update (when auto-update disabled)
pct exec <CTID> -- docker pull ghcr.io/athombv/homey-shs
Migration Guide
To migrate an existing Homey SHS installation:
  1. Run the installer and select No at “Autostart Homey SHS”
  2. Copy your userdata to the new container (/root/.homey-shs).
  3. Start Homey SHS:
    pct exec <CTID> -- systemctl start homey-shs
Troubleshooting
Container won’t start
pct status <CTID>
pct start <CTID> --debug
No network
pct exec <CTID> -- ip addr
pct exec <CTID> -- dhclient eth0
Homey SHS won’t start
pct exec <CTID> -- docker ps -a
cat /tmp/homey-shs-install-<CTID>.log
License
MIT License
Many thanks, this is impressive!
I have a current test setup with Proxmox VE and Backup server, where I try to learn the basic with the packages.
I will try your setup when I’m ready for the final transfer from Synology to Proxmox.
Just one question: if I select NO to “autostart Homey SHS” in order to copy the user data to the new container, will Homey SHS autostart with the the next reboot/s (like from an power outage)?
Yes it will. It will only prevent the direct start after it is installed.
You can reboot the Proxmox container or start the service as explained in Migration Guide.
edit:
:writing_hand: : Altered the question in interactive installer and updated the screenshot.
Thanks for the valuable feedback
Again, many thanks!
Just tested this and implemented this as my working SHS.
Worked as a charm, even my Thread devices which I currently are testing worked immediately.
No problem. I like to create these kind of things.
Good you’ve got SHS running smoothly now on Proxmox.
