Turn plug socket on when dimmer first is set to 100%
I have a dimmer switch connected to Hue and its also present as a light in homey. I’m trying to set up a flow which works as such: when the dimmer switch is set to 100% then and only then homey could turn on a power socket plug for me. Not sure how to setup this flow anyone got an idea?
@PaulDc , maybe I don’t understand your problem exactly, but I guess this flow would do the trick
https://homey.app/f/EhVFtq/
Or is the problem that your dimmer switch doesn’t have the trigger card for “dim value changed”?
That’s what i needed. I was thinking on right tracks I just messed the values up.
Thanks for your help.
