Hi i need some help,
I am placing a homey bridge at my parents house and a fibaro button.
When my mom needs help i want the bridge to send a signal to my homey pro when pressing the button.
I guess something with triggers over http. Can you help me?
Maybe you can add you’re phone to the Homey Bridge.
Add a user under settings, Family and guests.
I don’t have a bridge myself.
IF button is pressed
THEN Send a notification.
You can use a webhook
https://MyAthomCloudID.connect.athom.com/api/manager/logic/webhook/My_Event?tag=MyTag( Here you’ll find the MyAthomCloudID of your Pro at ‘cloudID’. )
In flow view:
2. @ Homey Pro
When…
-logics card: a webhook was received with event My_Event
And…
-logics card: tag [tag] contains MyTag
Then…
-do something
The “And” part is optional
In flow view:
I had the same use case and decided to install on her Pro a PushSafer App to also bypass a Silent mode on my Phone.
But that would not work from a Bridge, maybe you should indeed use a WebHook between her Homey (cloud / bridge) and your Pro.
