Is there way to a trigger a flow on any Homey activity? I would like to animate the led ring when Homey is executing any of the flows (doesn’t matter which). The only solution I see is to add the led ring animation to all the flows. But if I want to change this, I need to change all the flows.
Maybe I need to set a variable in every flow and monitor that variable to trigger a ledring animation flow. This way I can change the Led ring animation once.
Anyhow, I was wondering if there’s an easier solution.
