Hi peeps. There are two things I don’t understand here:
- I’m expecting this flow to trigger when the light “Taklampe gangen” is turned on. I turned the light on via the homey app, but it does not trigger the flow. If I have used the “Turned on” card wrong, please advice on how it is supposed to work.
- If i test the flow the light is not dimmed at the value in the given variable. If I remove the variable and enter a value it works fine. Also noticed now that the dim card things all my variabled are empty(they are not).
