Timed shut off if a device is off
Hi!
I’m having problem with making a flow work.
I want homey to turn off two smart plugs at 22.00, but only if my yamaha amplifier is turned off.
Example:
I turn off my amplifier at 21.20 and I don’t turn it on for the rest of the evening. Then homey should turn the smart plugs off.
At the moment I can only make it work if I turn off the amplifier after the slotted time.
Any ideas?
Try something like this:
  • WHEN
    • it is 22:00
  • AND
    • the Yamaha amplifier is turned off
  • THEN
    • turn off the smart plugs
I’ve tried that.
What happens is that I have to turn off the amplifier after 22 to make take affect.
If I turn off the amplifier before that time, it doesn’t work.
If your plug can measure power consumption you can do:
When 22:00
If power less then (stand by power consumption)
Then turn off plug.
Have you tried switching the conditions?
i.e. WHEN amplifier is off AND time is later than 22:00…
Btw on Homewizard, they had the same problem but they implemented a checkbox “evaluate at start” years ago which was very easy to use.
If switching conditions doesn’t work, try setting a variable and change it with flows to reflect the state of amplifier, then use AND variable is equal to…
Hey! I tried Alpol’s advice and that worked!
Thanks for your help all of you!
