I have created several Homey Flows that are supposed to run automatically at specific times, but they are not being triggered. When I test the Flows manually, they work correctly. I have also checked the location settings, and everything is configured correctly. What could be causing this issue?
Hi Nick,
For some unknown reason Homey time can get lost in space sometimes:
Okay thank you I will try it
Just delete the WHEN card and make a new one.
Unfortunately, nothing has helped so far. Perhaps a firmware reset would be a good next step to resolve the issue.
Before you start wiping your Homey, can you provide screenshots of a Flow that’s not working with timed start… one of us might be able to see or suggest something that might resolve your woes
Your flow seems fine.
Did you try @Peter_Kawa‘s suggestion regarding temporarily changing you Homey’s location?
If so, does it work after you disconnect power for 15 mins. and restart your Homey?
As in never, or hours early / late?
I’d like to suggest adding a timeline notification card to the Then part, which holds the time tag; this helps you monitoring such flows
When this card doesn’t appear within 24h, the trigger card seems to be damaged: build a new flow like the problematic one, and delete the original flow.
But first please reset Homey’s clock as I wrote earlier.
You might also wish to have a look at the Action Scheduler and/or Timey apps… possibly even Sun Events app. These are what I use for making things happen at a time, as I have found the Homey native time cards to not always be reliable.
Action Scheduler allows you to create a device as a trigger, then you can name that device after the automation, and instead of editing your Flow, just change the time in the device properties and your Flow starts at a different time.
Timey allows you the ability to use a variable for a time, so you can use Flows to change the time another Flow runs.
And Sun Events has many useful triggers, like sunset, or between sunrise and sunset with an optional offset of X minutes… so automations change with the time of year automatically.
Okay, which app do you use for that?
