Tibber pulse flow
Anyone have any tibber pulse flows to share? Would appreciate some input in this matter.
Moved to Flows.
I am also looking for input on Tibber Puls flows. Currently I have the hot water tank off when the price is more than 7.5 % above daily average.
I would like to have this a little bit smarter, so it won’t be turned off for too many hours in a row. Any input is appreciated :slight_smile:
https://homey.app/f/uzXg3Z
https://homey.app/f/qFch3Z
Using these two, activated on a fixed spotprice.
Have a Brand new 300l tank, so can turn off power 8 hrs during day, basicly from 08-16 when power is most expensive.
https://homey.app/f/i9Ih3Z
This one for protection regarding main breaker, it breaks off on about 10600 watts, so Homey turns off units at 9500 watt, and preventing main breaker going off.
Thanks for sharing your flows, @Tangodelta.
I guess I could implement the same as you, on a fixed spot price, but I was looking for a “smarter” logic considering average price and avoiding keeping the units off for too many hours at a time.
My heater is from the 1960s, so I can not have it off 8 hours. Should probably replace it :stuck_out_tongue_winking_eye:
Hi All,
Are in a position where I like to use the advantage of Tibber to control a few consumers.
First of all the app is in place but no Tibber conditions can be found, if understand it correctly it will only work if I have pulse or watty?
Is that correc? can’t understand why majority of the specified conditions that can be used requires that hardware?
//Daniel
Hi all!
I am trying out this flow now: Shared Flow | Homey
I suspect it will work fine when the price is going up, but less fine when price is going down.
Living with my family I need the hot water all around the day… Anyone having a suggestion on how to include “smartness” when price is going down?
Best regards Arnfinn
