Temperature in F or C - option to switch
I am from the USA and use farenheit, but I just added a Homey Pro to our Latin America house and have no way to see anything other than in Celsius. It would be great to have the option to change this.
If I’m not mistaken Homey change Celsius to Fahrenheit (and the other way around) based on the location you have set in Homey.
Could you check if your location is correctly set ? If so, could you change the location to a different country, save it and than change it back to your location. Sometimes this solves issues with the location..
I think the problem is that Latin America mostly uses Celcius instead of Fahrenheit, @Justin_de_Knegt .
If I am not mistaken, @Andi_B?
Perhaps it would be good to create a feature request at Athom Support, although I doubt if it would not get very high on their ToDo list. But I do agree it would be nice to be able to manually change such settings…
:backhand_index_pointing_up:
Ah that is something I was not aware of if that is the case, than my suggestion indeed won’t help.
But I agree, something like a toggle in the general setting menu to switch manually between them would be a nice thing to have.
:joy: USA and the Kaiman Islands are the only in the world using Farenheit :joy:
