Tapo Camera C260 cannot be installed
Hello everyone,
I am trying to integrate a TP-Link Tapo C260 camera into Homey Pro Mini using the official Tapo app.
Current situation:
  • I can successfully log into my Tapo account from Homey.
  • The camera works correctly in the Tapo app.
  • ONVIF is enabled on the camera.
  • RTSP/ONVIF stream works perfectly in VLC from my PC.
  • Camera and Homey are on the same local network.
However, when I try to add the camera in Homey through the Tapo app, Homey does not detect/find the camera at all.
I already tried:
  • rebooting Homey
  • rebooting the camera
  • removing and re-adding the Tapo account
  • verifying ONVIF and RTSP functionality
Is the Tapo C260 officially supported by the Homey Tapo app?
Has anyone managed to get this specific model working correctly?
I am also wondering if the issue could be related to:
  • unsupported/new model
  • API compatibility
  • cloud discovery limitations
  • local network discovery issues
Any help or confirmation would be appreciated.
Thanks!
Are the camera and Homey on the same network? This is required for the cameras
As I said in my current situation:
You should report your issue in the app topic:
Instead of using the Tapo App use the ONVIF camera App. It works great with Tapo cameras.
I have this same issue , that it worked on hp2023 but not self hosted docker in unraid, from what I can find it has to do with the docker using macvlan and needs to be changed to ipvlan, but when I change it to ipvlanthe docker looses all connections :frowning: And I’m not sure how since everything i did and AI said to do didn’t work
