tapo C560WS
Hi! Could you add support for the Tapo C560WS (4K outdoor pan/tilt) to the app?
The C520WS works great, but the C560WS can’t be added. It supports ONVIF (port 2020) and RTSP (port 554, /stream1 main + /stream2 sub-stream) with a camera account enabled — I’ve confirmed both ports are open and reachable, and ONVIF login succeeds, but no stream comes through (likely the 4K main stream). Firmware: [vul je firmwareversie in]. Happy to test a beta version. Thanks!
I think you could better try to ask this in the app topic of tapo: Tapo app
Did you even check your AI generated post?
