Switching 12V
I’m looking for a 220V AC (or 12V DC) Z-wave (or zigbee) relay that can switch 12V.
Would appreciate some advice on this.
Thanks
Figaro z-wave relay, Shelly z-wave relay, both can be powered on 220VAC and switch whatever you feed the input, such as 12VDC.
You could use a relay switch that is marked as “potential free” or “zero volt contact” or “volt free”. As mentioned, Shelly and Fibaro have options, but there are more manufacturers that create zigbee, z-wave or even 433mHz options.
Thanks guys for your info. I think i will go for the fibaro as i have good experiences with Fibaro.
