Relay switch with 24VDC circuit for push buttons (cabinet assembly, DIN preferrable)
My case is to find a device as below:
  • mounted on a DIN rail in cabinet (can be also normal (wall) version, I will print holders)
  • relay switches to control 230VAC outputs for lights
  • as an input, I want to use push buttons with UTP connection (5e cat.) directly wired to the cabinet
  • so for switches need to be low voltage (for coil) 12-24VDC, but as an output, 230VAC,
  • preffered communication: Zigbee, Wi-Fi or LAN,
  • due to more then 15 circuits, we can speak about single modules and as well, multi output boards.
I searched forum for a different working devices with Homey with no success. Best buy guide does not help: [Smart DIN Rail Modules | Best Buy Guide]
There are some boards on Ali with ESP32 (those should work in general) but I am not sure, if really circuits for switches will be 12 or 24VDC and outputs 230VAC.
I want to avoid to install relays in a wall behind switch and put there standard wiring.
Thank you in advance for support and suggestions.
