I try to add the Switchbot mini hub and temperature / humidity sensor IP65 in Homey pro.
The sensor isn’t visible in the Homey app.
I tried the hub, but after logging in with Switchbot email and password the device isn’t found.
is it possible to add this hardware?
How are you trying to add them, using Matter or the SwitchBot app?
I tried Matter and yes, the hub mini is connected now.
But how to add the IP65 temperature / humidity sensor in Homey? The sensor is connected in the Switchbot app.
Have you added it to the hub as a shared device?
Yes, and yesterday I tried again after a reset an now it works fine!
Problem solved.
Thanks for supporting.
