Hi There,
Recently I bougt a Steinel IS 140-2 PIR sensor. The idea was to let it trigger my IP cam (Foscam). Making the flow and getting it to work was super easy. This PIR sensor should trigger on body heat & motion. The cam triggers only on motion witch resultet in the recording of leaves moving in the wind. PIR should solve this problem and only trigger on body heat (People & Animals).
Why is my sensor still triggerd false? I Tried adjusting the sensitivity (now on 20%). It triggers much less but still when there are no people or such.
Q: Can it still be triggered by leaves or other lifeless objects?
Thanx and regards,
F.
