hello, i’m using homey now for a while but i want my shutters to me connected also…
i have a shutter with motor from INEL … some company from poland… the controller is the one on the image and i think they use 433 mhz protocol to connect the remote… Can anybody explain how to connect it… or find a way to make it connectable ?
You will not be able to control this directly from any Homey. The communication on 433 MHz uses rolling codes according to Inel, that is, each time you send a command it will use a different code than the last time.
If you have a Homey Pro and the “hub” from Inel you may get it working through some clever use of HTTP requests. I see people running Home Assistant seem to have succeeded.
Oké and i only Need to send it a up or down command…. So no feedback if its closed or something… is that also nog possible ?
No, not directly from Homey.
