Keylite roof window remote control 433MHz
I would like to connect my 2 Keylite roof windows to Homey Pro via a 433MHz remote control. There is no Keylite app available.
Is there a way that Homey can read my remote control?
Or maybe another way?
KL-electric-op-remote
Remote control
No, someone needs to create an App for that first.
Search for other devices like a Broadlink RM Pro Plus or so that can learn and re-transmit FR signals.
But this Broadlink App isn’t maintained at the moment and not compatible with the New Homey Pro (Early 2023) only older Homey - Pro’s at this moment.
Yes, unfortunately no App for it yet.
I had also found the Broadlink RM Pro and accompanying App, but not suitable for the Homey Pro.
Hopefully someone wants to make a Keylite App. I can’t do that myself.
Thank you for answering.
Guys,
@fkmeland is busy with upgrading the Broadlink app :partying_face:
@J_de_Boer Try the Brel app, it recognizes some foreign 433 remotes and can learn the signals. When it succeeds, you can trigger almost anything connected to your Homey.
I have a no-name (Tuya) curtain 15-channel remote and it works :partying_face:
@Peter_Kawa thanks for the tip. I will install the Brel app as soon as possible and post the result.
@Peter_Kawa, Unfortunately the Brel app doesn’t find the Keylite remote.
I’m going to follow @fkmeland’s Broadlink app.
If anyone else has any suggestions for my Keylite remote, I’d love to hear them.
If you let Google Lens analyze the picture of the remote control you will see, that this remote control is distributed under several brand names (Brel and also a lot of others). You could try to look for a Homey App for those brands.
Via Google Lens I came across the following manufacturers; Venetian, iSmart, Diaz.
But none of them I can find in an app.
The Brell DD1802 is similar (3 buttons less) but cannot be selected in the app.
Here’s an update.
I have now purchased a Broadlink RM4 Pro, but unfortunately I cannot connect the Keylite remote control.
I have now discovered that the remote control uses rolling codes.
Unfortunately, the Keylite supplier and manufacturer in England could not or did not want to tell me that.
Unfortunately, I have to give up and cannot connect my skylights to the Homey.
So my Broadlink RM 4 Pro is for sale.
