I then assumed it should be the normal Homey login, but I am not able to log in (I’m using Tera Term), authentication fails. Anyone else had the same, and if so, how did you fix it?
Ah. I had enabled the experiment a long time ago, I just hadn’t tried it yet. And I had of course forgotten about that popup box when I enabled it.
As you correctly point out it is actually mentioned in the last section of the linked article, I somehow missed that. In my defence, I think perhaps it would have been a good idea that they mentioned this more explicitly at the top of the article.
