[SPONSORED] [REVIEW] Repenic Zigbee Toggle Switch Review – Premium Design Meets Smart Home Control
Can a smart light switch look and feel as good as a premium traditional switch? I’ve been testing the Repenic Zigbee Toggle Switch with Homey to find out.
This review is entirely my own. I have been sent this switch for free from @Repenic in return for a review but the words and opinions are all mine.
Who Are Repenic?
When it comes to smart home technology, functionality often takes priority over appearance. We have some fantastic smart switches, sockets and modules available, but many of them share one thing in common: they’re fairly uninspiring to look at. White plastic, basic finishes and designs that don’t always complement the rest of your home. This is where Repenic are doing things differently.
Repenic to my knowledge are a relatively new name in the smart home market, taking a more design-led approach to smart home technology. Rather than focusing purely on the electronics hidden behind the wall, they’ve created a range of premium-looking electrical accessories that combine traditional styling with modern smart home functionality.
Their range includes toggle switches, rocker switches, dimmers and sockets, with finishes such as brushed brass, stainless steel, matt black and matt white. The idea is to offer a coordinated range that looks just as at home in a traditional property as it does in a modern interior; and this is something I think has been missing from the smart home market.
You might spend considerable time and money choosing the right lighting, furniture and finishes for a room, only to end up with a fairly basic plastic smart switch on the wall. Alternatively, you might install an expensive decorative switch and then have to squeeze a separate smart relay module behind it to make it work with your smart home, meaning deeper backboxes or spacers behind the switch. Yes modules have got a lot smaller in recent times but they still require depth.
Repenic are aiming to bridge that gap, offering attractive, high-quality switches and sockets with the smart technology already built in.
Their Zigbee range is particularly interesting because it offers compatibility with all established smart home platforms, including Homey. This means you’re not necessarily tied to a manufacturer’s own hub or ecosystem, something im a big fan of
I’ve been given a Repenic Zigbee Toggle Switch to try out, and for this review I’ve connected it to my Homey system to see how it performs.
First Impressions – Build Quality and Design
The first thing that impressed me about the Repenic Toggle Switch was the build quality.
Picking it up, there’s a reassuring amount of weight to it. It feels like a proper, premium electrical accessory rather than something that has been designed to hit the lowest possible price point. The faceplate feels solid, the overall construction is sturdy, and there is nothing about it that feels flimsy or cheaply made. Another nice detail is on the rear of the faceplate, where Repenic have included small foam strips. These help prevent the plate from slipping or moving against the wall and give it a more cushioned, considered feel when installed. This might seem like a small simple addition, but it adds to that luxury feel.
The toggle mechanism itself is particularly satisfying. It has a firm, positive action with a distinctive mechanical click when operated. It’s the sort of switch that feels good to use, rather than the hollow, plasticky action you sometimes get with cheaper alternatives.
This toggle switch also looks quite different to your average switch, it has more of a retro feel as a small bar with knurling on rather than a standard switch
That might sound like a small detail, but a light switch is something you interact with multiple times every day. Having a switch that feels properly engineered makes a noticeable difference.
Overall, the Repenic looks and feels like a premium traditional switch first, with the smart technology being an added benefit rather than the main focus of its design.
Installation
One of the biggest frustrations I’ve experienced with smart wall switches is the size of the electronics behind the faceplate. Quite often, the smart components make the switch considerably deeper than a traditional light switch. This can cause problems in UK homes, particularly when you’re working with a standard shallow back box, meaning that what should be a straightforward replacement into a much bigger job.
Thankfully, this is one area where Repenic have done a good job.
Despite having the Zigbee electronics built into the switch, the Repenic is designed to fit into a standard 25mm UK back box. That’s a real advantage, especially in existing properties where replacing or deepening a back box isn’t always practical.
However, in my opinion there is one significant drawback. The Repenic Zigbee Toggle Switch requires a neutral wire (not all of their devices do so be sure to check) For anyone familiar with UK lighting circuits, you’ll immediately understand why this could be a problem as In many UK homes, particularly older properties, the traditional wiring arrangement at the light switch consists of a permanent live and a switched live, with the neutral connection remaining at the ceiling rose or light fitting. This means there often isn’t a neutral wire available at the wall switch itself and it’s not easy to pull one in.
Unfortunately, that makes the Repenic unsuitable as a straightforward replacement in many existing installations unless the required wiring is already present or additional electrical work is carried out and that’s a real shame.
There are other smart switches and modules on the market that operate without a neutral connection, so it would have been great to see a similar option from Repenic across their whole range.
A neutral-powered design can offer advantages for powering the smart electronics, but from a UK retrofit perspective it does limit where these switches can easily be installed.
For a new build, renovation or property where neutrals are already available at the switches, this won’t be an issue. However, for someone looking to replace existing switches throughout an older UK home, it’s definitely something to check before purchasing.
The fact that it fits a 25mm back box is excellent, but the neutral requirement does take away some of that installation convenience.
Connecting the Repenic to Homey
Getting the Repenic connected to Homey was refreshingly straightforward. When adding the device, Homey suggested installing the Repenic app, which made the process simple. After installing the app and putting the switch into pairing mode, Homey discovered and connected to it immediately.
Over the years, I’ve had more than my fair share of devices that take several attempts to pair, require resets or need some creative troubleshooting before they finally start working There were no pairing failures, repeated attempts or complicated workarounds. For a relatively new brand, this was a very positive first experience. Once connected, the switch appeared in Homey and was ready to control. The whole process was quick and painless, which is exactly how adding a new smart home device should be. The Repenic simply connected and worked.
Performance and Responsiveness
Once paired, I spent some time operating the switch through Homey, and the initial results have been very good.
The Repenic responds quickly to commands sent from Homey, with very little noticeable delay between issuing a command and the switch responding. This is exactly what you want from a smart light switch. The Zigbee connection has been responsive during my testing, and controlling the switch from Homey feels quick and natural.
Of course, a longer period of use will be needed to assess reliability over time, but first impressions of its responsiveness are very positive. This brings me onto the Zigbee connection
Zigbee Connectivity and Reliability
One area where the Repenic has particularly impressed me is its Zigbee connectivity.
A few months back I moved all devices off my Homey Bridge and into Home Assistant via Zigbee2Mqtt. So at the time of testing, this is actually the only Zigbee device connected to my Homey system. This means the Toggle switch has not had the benefit of an established Zigbee mesh network with multiple devices helping to extend or hop the signal. Despite this, I’ve had absolutely no issues with connectivity. To further test this I’ve moved the switch to three different locations around the house and the loft room is 2 floors above my Homey Bridge. In every location it has maintained a reliable connection to Homey. I’ve experienced no signal drops, devices going offline or instances where the switch has failed to respond to a command.
Obviously, Zigbee performance will depend on the layout of your home, wall construction, interference and distance from your hub, but based on my testing so far, the Repenic has performed extremely well.
This is one of those areas where reliability is more important than having an endless list of features. A smart light switch needs to work every time, and so far the Repenic has done exactly that.
Power Monitoring – More Than Just On and Off
Another feature I was pleased to discover is that the Repenic Zigbee Toggle Switch also supports power metering.
This is a useful addition and gives the switch another level of functionality beyond simply turning a light on and off. The power consumption information is available within Homey which means it can also be incorporated into Homey Flows. This opens up some interesting possibilities for automation. Energy monitoring and automation is huge these days so this is great to see.
Price and Value for Money
At full retail price, the Repenic switches certainly aren’t the cheapest option on the market, and they may seem a little expensive compared with some of the more conventional smart switches available. However, I do think you need to consider what you’re getting for the money.
I’ve been building and experimenting with smart home technology for over 12 years now, and during that time I’ve used a lot of different switches, sockets and smart home modules. In terms of overall build quality, appearance and the physical feel of the switch, the Repenic is genuinely one of the nicer products I’ve come across. It feels more like a premium electrical accessory that happens to be smart, rather than a smart device that has had a decorative faceplate added to it.
Of course, whether that justifies the additional cost will depend on what you’re looking for.
If you simply want the cheapest way to control a light through Homey, there are more affordable options. But if you’re renovating a room, upgrading your electrical accessories or want something that complements a carefully designed interior, I can certainly see the appeal.
Repenic currently have a Black Friday promotion coming up, which could make their range a more attractive proposition for anyone considering trying them out. With a discount these are definitely worth a buy.
Repenic aren’t just producing smart light switches; they offer a growing selection of smart home accessories, including sockets and central heating controls so follow the link if you would like to buy their products at their black Friday prices.
Supporting Homey – A Welcome Approach
Another thing I really like about Repenic is their willingness to support platforms such as Homey.
Over the years, I’ve seen plenty of smart home manufacturers focus almost exclusively on the usual big ecosystems, such as Apple Home and Amazon Alexa, often leaving users of other platforms relying on community integrations, workarounds or additional hardware.
It’s therefore refreshing to see a relatively new company embracing Homey and making its products accessible to those of us who prefer a more flexible smart home system.
Having a dedicated Repenic app available in Homey, with straightforward pairing, responsive control and access to additional functionality such as power metering, is a big positive in my opinion. It’s exactly what I’d like to see more manufacturers do
Hopefully, as Repenic continue to expand their range, we’ll see even more of their products supported within Homey and more possibilities with flows and automation.
Conclusion.
Would I buy it. Yes
Overall, I’ve been genuinely impressed with the Repenic Zigbee Toggle Switch. Yes it’s a little on the expensive side for a switch, but as discussed your getting a premium product that is available in a number of finishes that will actually make your room look smart and work smart. Not just your typical white plate.
I do not get any paid promotion or further discount from Repenic and all views are my own. Please give them some support and check their other products.
They have their black Friday sale online now until the 30th of November offering 15% off sitewide
Follow this link to get your products
Repenic Homey Black Friday Sale 15% off
Thanks to Repenic for sending me this product and Thanks for reading
