I’ve been using homey to automatically start a playlist on several sonos speakers every morning.
I’ve created a flow that works perfectly, but it ONLY works after i’ve manually restarted the sonos app in homey. If I don’t do that, no music.
Does anyone have experience with this and knows how to fix it?
Have been experiencing issues with the sonos app for a while. Ultumately ive switched to setting up a Sonos HTTP API docker container to solve my own issues. So that’s a route you can consider to take, but only if you have some experience with setting up docker containers.
The other option you can consider is to restart the app first through the same flow. This can be done by enabling the power user settings (settings → experiments → power user).
Or perhaps contact support@athom.com?
Yeh… that’s always an option too… not the quickest though
I have no problems with the Sonos app. The only bug I know of is that the “plays/doesn’t play” function doesn’t work.
Could the wifi be causing the problem? Do the speakers have a fixed IP?
