Somfy 868 Mhz supported with Pro 2023?
I see different info on this; can I control my Somfy screens (868 Mhz) remotely with Homey Pro 2023?
Homey Pro does not have RF 868Mhz, and btw that never worked on Somfy anyway.
If you have Somfy that can be controlled with one of these Hubs, you probably can connect them on Homey thru that Hub.
Connect your Somfy TaHoma, Switch or Connexoon account to Homey then control and read your devices, sensors and scenarios directly from Homey.
On this page Somfy | Talks with Homey
I read: Because Homey makes use of 7 wireless technologies, you won’t necessarily need a Somfy Tahoma Box to connect all your devices at home.
That’s only RTS on 433MHz.
A google for that gives IO Homecontrol
Search for that on this forum, everything about that is said,
O, and also everything about that is Sad…
Thank you for the reply.
My screens may be 433, i’m not sure anymore. If they are 433, will I then be able to control my Somfy screens?
I control them now with a Telis 4 Soliris RTS remote, I read it is 433 mhz.
in that case try the Somfy RTS App for Homey | Homey
it could work, also depending on distance / interference …
