Homey and Somfy rts
Hi all!
I’m about to buy myself in the Homey community after doubting Home assistant vs Homey for many years. I only cant figure out if my Somfy RTS 433mhz screen will directly communicate with Homey Pro or that I will still need the Somfy connectivity kit for this. If its the latter, I might as well buy the Homey pro mini later this year as I have no other use for the 433mhz module in that case.
Any thoughts?
Yes
Make sure you have Somfy RTS and not iO,
Have a look at your remote control: Rolluik Somfy RTS - #22 by Birger_Naert as @Birger_Naert was also confused.
Yes works, 3 screens all RTS directly.
I bought the homey pro and it works flawlessly indeed. Thanks for your replies!
Can others confirm if the tile for Somfy blind changes color when opened vs closed. For me it’s the same which is frustrating for a window cover. Current working around via HA app and presenting as cover.
No it does not change color but I think that is due to the fact you use RTS, which sends no status back. It’s one way traffic, unlike Somfy IO. Tbh I don’t really care, as I automate my blinds. If I order it to open, and it’s already opened the Somfy motor stops the request anyway.
Thanks for confirming @SandwichDeLuxe
