Hi, I tried a search with no results so I thought I’d ask. I am currently using Smartthings which I find ok but not really as ‘complete’ as it was made out to be, so I’m thinking about transferring over to Homey however I have invested in quite a few Smartthings power outlets and wanted to know if they are compatible with the Homey?
Iv’e read that the Smartthings sensors are not compatible, is that still the case with the v2.0 firmware?
Also is it possible to run a Smartthings hub and Homey at the same time on the same network?
Athom states that “Homey is a full-fledged SmartThings alternative, the SmartThings Hub can be fully replaced by Homey”: https://blog.athom.com/?p=3544&lang=gb
So I assume that the sensors should work. If not, ask Athom via the request form why not.
“This means Homey’s technology can connect to almost everything the SmartThings Hub connects to (SmartThings’ own sensors being a notable exception), and adds a lot more, like your TV.”
That didn’t change, the blog was written on feb. 1st, so after Homey v2 came out… It’s Samsung’s way of preventing users to switch over to competing and better systems…
