Smartthings 2 app
I know Dominic Vonk is working on a new Homey community store but ever since I have my Homey 2023 I miss the Smartthings 2 app from the former HCS.
With that app I could add my Samsung soundbar from Smartthings. I used it that way because with the Samsung Wireless Audio multiroom my soundbar goes on/off all the time so that is not an option. With the regular Smartthings app I can’t add my soundbar.
Is this Smartthings 2 app somewhere on Github (could not find it) and addable with CLI ?
If not than I just have to wait until Dominic Vonk has the store up and running.
Thanks.
search for Smartthings 2
That is a really helpful reaction.
Thank you. :+1:
I needed to do some things to get it working but I have got it installed now and my soundbar is working again.
Possible to add snapshot when motion is detected on doorbel?
Sorry to open this topic again, I still have the SmartThings 2 app installed, though I can’t seem to find it in the app store anymore. (Don’t know what to do this the above mentioned github)
I mainly use it to control my washer and dryer. Set in to run when the power is cheap. However my devices can no longer can be controlled, only view the status. I’ve installed the other SmartThings app, but it’s no longer maintained and can only control my washer. Not the dryer.
The athom SmartThings is rubbish al togheter. As it can only show if it’s running.
This is the app, by Adrian Rockall, which has moved to the app store, Fabian:
Works great.
Set this app last night and it was awesome. All devices in and working well. However i then noticed after 5 mins ir so all devices would go offline then after a minute or so come back on.
This morning all devices had disappeared and the app had crashed. I restarted the app but no device works and i get a “Timeout1000ms” warning.
Is this to do with the refresh rate i set when i created the access token?
I have 200 devices. Whats my best options please
Thanks
Wow, 200 devices is a lot, so collecting all that data too fast could be using a lot of cpu time causing Homey to shut it down.
I’m not sure which app you are using, but if it’s mine then you can change the polling rate in the app settings page.
Im using the SmartThings community app. Is there another or different perhaps better one?
Thanks
All three use the same API, so probably not much in it apart from supported devices.
Have you tried reducing the polling rate to see if the app becomes more stable?
What are the 3?
I cant see in my settings where to change polling rate.
Thanks lots
Just enter “samsung” in homey.app store search bar
How about goto Apps > open Smartthings app > Cog wheel > App settings
Changed to 65 seconds.
Crashed! :confused:
Logs are saying cpu warn!
It wont let me change it to more than 65.
Ill try move alot of the devices over to homey natively and see if that helps. Was hoping to save the time lol
