Smart wall controller with display?
I would like to have some kind of wall panel, with some buttons and a display. I would like to be able to fully configure buttons and data to be shown on the display, ideally using Homey flow.
Example Homey flow I dream about: when I press button A on the controller, increase temperature on Eurotronic Spirit and display current target temperature on wall controller. After a minute display current temperature from Aquara temperature sensor.
Second example: when I press B button on controller, set light color to cold white and show “cold white” on wall display.
Third example: display current value of external thermometer sensor (or whatever else sensor) untill I press some button.
Is there a device I could use?
Ideally it should talk with Homey via z-wave or ZigBee, WiFi is also fine. RF no because of range issues.
Search this forum for “dashboard”
If you’re not looking for a plug and play device, you can build your own with arduino, Homeyduino display.
I created a alarm panel based on a M5Stack, which connects through MQTT. Via MQTT it is fully customizable.
You can also program the M5Stack with homeyduino i guess.
see: https://github.com/rhannink/M5Stack-HA-Alarm-panel
Gr. Remco
M5Stack seems to be nice, I’ve never done low-level programming but well… looks like a good challange for me :slight_smile:
