Since update 12.4.7 no Cloud connection when using PiHole addblocker
Since the update to v12.4.7 last night my Homey Pro 2023 isn’t connected to the Homey Cloud anymore.
I already rebooted everything, including local network. But still no connection.
Can someone advise me what to do?
Are more people having this issue?
No issues over here. Running same version. Maybe the problem is in then network? Did you restart your router already?
Local network already rebooted. And other services that using the same technique to acces local resources are working perfect.
So it has to be a Homey related issue.
What if you power down your Homey (unplug it from power), wait 15 mins and power it back on?
Thanks for the replies.
It turned out to be a local issue after all.:see_no_evil_monkey:
After a while of troubleshooting I discovered that the Pihole adblocker was blocking a lot of traffic since last night. It began around the same time as the new Homey firmware was deployed.
Allowing all Homey domains solved this issue :grinning_face:
List of domains used:
*.athom.com
*.homeypro.com
*.homey.com
Can you report the domains you whitelisted as help for others here.
Done
