Showcase your Dashboard
Please do write in english for all people to be able to contribute.
Hi @Anders_Gregow
You are absolutely right.
If a person start asking questions in my native language in an english tread I just start typing out of enthusiasm in dutch.
Will never, ever happen again :wink:
Here is my setup. Samsung tab 9+. Velcro fastening to the wall.
Controlled via kiosk mode and motion detector for automatic switching on and off, and Charge.
The only thing that doesn’t scale well is the Plex app.
Furthermore, very happy with dashboards.
How did you get 4 columns on your A9+?
What settings did you adjust to what value?
Go to Settings > Display & Brightness, then select the smallest text size, and Zoom in on screen to smal.
My dashboard at this moment, first setup and cant wait til athom provide us with more design options and widgets. Onestly the standard homey tiles look terrible on a dashboard, assuming they will give that a redesign in the future.
btw dont start about the name dasboard :rofl:
I really hope so :rofl:
Do you use the “Fully Kiosk Browser” app?
He will need to use the “Fully single app Kiosk” app for that :slightly_smiling_face:
correct, “Fully single app Kiosk”
Is your buienradar refreshing @Peter_Kawa mine stays on the same time
Refresh the page every 60sex
When closing the honey app it’s working
It’s a bit fuzzy with iframes / web widgets.
I also read lots of other things don’t auto update.
But your buienradar is refreshing ?
Hi @Mariomark1541
I reported this some time ago at support. It is refreshing every minute. So do not blink your eyes. Otherwise you do not see which direction the clouds are going.
And I (and assume many outhers) want to see a 3 hour forecast.
This is the Athom buienradar widget. Not the iframe widget.
@Doekse
I send support an email about this but never received an answer.
Rogier
How do you make de gauges in Homey? I can’t find it.
DataVista widget, Ria
Here’s my concept dashboard since I discovered that I can use HTML code in the Status Display of Enhanced Device Widget.
So basically what you see is simply text, in html format, with links to logic variables.
Those variables I set up before to create my own energy oversight, so I only had to put them in a dashboard to create this.
This is just early stage… one evening of work. But I really like the fact that even html table coding works. So I got this right now.
And when active it changes to
(Don’t pay attention to the numbres, as they are currently incorrect due to calculation changes)
For convenience I coded the HTML in an external program, en copied it in an advanced flow.
The logo’s change based on a simple boolean value from logic variables.
I saved some space in the header where I will add the current power consumption.
And these logo’s where quickly found on the web, but I will make better ones for my own in photoshop when I have some spare time.
Really happy with this result so far.
Nice to see you dived into the Enhanced Device Widget’s possibilities!
@Adrian_Rockall check that dash :point_up_2::point_up_2::point_up_2:
