Show variable on button in place of energy
Thanks again Arie! It works perfect on my dashboard, and for me that’s perfect.
Thanks for the hint to switch zones to make it update inside the mobile app.
Please note that i am working on a upgrade which would probably mean it is better to recreate the device after next update. (or recreate the fields through settings so flows don’t break)
Sounds promising. I would be happy to add one capability several times (measure_temperature or similar) with a unique description for each capability. This way it would be possible to combine more than one sensor into a virtual sensor.
Comming up next:
Fully configurable fields, 4 text, number, yes/no, and buttons.
And one status field (because setting this is a have resource and you can only select one Status Indicator).
All text, even in flows, are the one’s you give in the settings :slight_smile:
Change name to Status1
Anyone who could suggest/write a good Description voor this new devices for the Store description?
I am so bad at making clear what you can do with it, at least, if i can’t use images.
Test version:
Updated because of a simple bug: 1.9.1.
One more bug for triggering the first button, fixed in test in 1.9.2.
Hi Arie,
What an amazing improvements!
Did some more testing.
I added a v. device (v1.9.2), all went well.
But I can’t add another device :grimacing:
So I removed a few ‘old’ devices, restarted the app, but no difference.
It says ‘No new devices found’ or it times out after 30s.
Edit After removing the app and installing it again, I can add more than 1 virtual capability devices again :heavy_check_mark:
Similar results in the web app.
Will try.
m, il try to fix it.
Gonna eat now, going at it tonight again.
No hurries!
This is probably me beiing stupid but its not immeditely clear to me how to add a field/text/number to the device button… ?
Have a look at Advanced parameters…
I saw that… i can find how i change texts on the page you get after you open the device bu pressing the button… but i cannot find hoe to change the text on the button ?
In the Mobile App, Select the Status as Status Indicator.
Then use a flowcard to set the Status.
Please update to the new testversion 1.9.3.
And then use the flowcards Set Status to [[text]]
@Marc_Jurriens Visual, something like
Device:
Screenshot_20220826-153927_Chrome
That would be exactly what I would like… I will try to find it again.
Update to test version 1.7.93 for much great improvements.
Status indicator seems to be removed on device type Thermostat, has anyone else had this issue? Also can’t see where to create custom lists.
