What's the advantage of virtual devices vs flows?
Hello all!
Out of interest. What is the advantage of using virtual devices rather than just flows and boolean logic values?
I have, for example, a logic value that I update depending on if I have my phone on charging or not (via Shortcut). Today I’m just updating a boolean value (IsCharging = Yes/No) but maybe I’m not using best practice here? Are there advantages of virtual devices that I have missed? A clear disadvantage is obviously that I have “devices” that aren’t really being used and it messes up the UI when I manually control my home.
Which Virtual Devices do you mean?
The builldin expirement?
The Virtual Devices App?
Or the Advanced Virtual Devices from the Device Capabilities app?
A virtual device shows in which flow it is used. For me that is a big pro.
(I creaapted a seperate zone ZZ to store the virtual devices that I do not use in the control
Well, was thinking of the built in experiment. Didn’t even know about the apps?
Hmm, care to elaborate? Not sure I fully get it
When you hold a vitual device button you have the option to view all flows that the button is used in
If I would use a variable that is set, I would not be able to trace in which flows it is used.
I find it very usefull for troubleshooting to I can easily trace where settigngs are used…
Best for this would be the AVD from device capabilities.
Create an avd for each group, and you can add as many fields/variables that you want, of any type, give them custom names, icons, etc.
AVD seems very cool! Will check it out!
