Virtual Device Config
I have two VD’s which I thought were both set up the same but it seems they are not.
It seems that it is not possible to see how aVD has been configured when it was initially created. Is this correct?
From what I can see of their behaviour one is a on/off switch and the other is a boolean device true/false. Yet they both work just the same in a flow. Most likely as the only flow card I use is When Pressed/Changed.
Which one of the various virtual devices app are you using?
VD native (when you enabled experiments)
VD app
Advanced virtual devices (device capabilities app)
Can you show your flow?
Thanks for offering help, but I deleted it (VD from VD App) and then re-added it as a switch. It is now behaving as expected.
