hi every one,
I currently have the following connection:
3 wires coming out of the motor side: 1 brown, 1 yellow, and 1 blue.
Each wire is connected to a wire of the same color going into the electrical panel (connection made with a terminal each to connect them between wires of the same color).
Then everything is controlled by a wireless switch made by the same brand as the motor.the brand is called Simu
Do you have any idea of ​​the best connection for the Shelly Wave Shutter module? Thank you.
I should point out that the radio frequency between the switch and the motor is in BHZ format.
